Front mini-USB ports broken
Posted: Mon Nov 16, 2009 12:01 am
Don't know if anyone else has this problem...
I am using the two "official" USB-A to mini adapters I ordered from Amazon.
When I try to boot using the two front USB ports for my keyboard and mouse, only one of the devices is detected (only the device plugged into the outside port, the port on the right as you look at the front of the fit-PC). If I remove the adapters and plug the devices into the rear USB ports of the fit-PC, they work fine.
When plugging in two USB external drives, both power up, but neither are mounted or otherwise recognized by the system. If I remove the adapters and plug them into two of the rear USB ports, all works perfectly.
Do I have a faulty unit, or is there an issue I can expect to be fixed?
Jim
Jim
