Realtek GBE driver does not start
Sailor
Post by Sailor »
I've installed Windows 7 on my Fit-PC2. Everything is working smoothly, with good graphics performance, so all in all to be recommended.
I do have one nasty problem: the wired Ethernet card does not work. The driver is at level 7.6.820.2009. It reports the following problem:
Realtek PCIe GBE Family Controller
This device cannot start. (Code 10)
Does anybody have a clue as to what could be causing this?
I've tried the following to no avail:
- Update the BIOS (version DEVEL34X, 31 Aug 2009).
- Run with/without cable.
- Have Windows try to upgrade the driver.
Sailor.
Re: Realtek GBE driver does not start
Sailor
Post by Sailor »
Sorry, I should have said that that is where I got the driver from.
You may want to rule-out hardware problem by trying with another OS.
Return to “Windows 7”
