Watchdog Timer
arkestler
Watchdog Timer
Post by arkestler »
I see there are instructions on the wiki on how to use the watchdog on Linux, what needs to be done to use it on FreeBSD? When I activate the Watchdog timer in the bios it just keeps rebooting the system at the interval I have set. How do I make FreeBSD work so that it only reboots when the OS has locked up?
Re: Watchdog Timer
Hello
We do not support FreeBSD, but I think it will help you if you will look to the source of the linux drivers to see the values of the registers written to manipulate the watchdog
arkestler
Re: Watchdog Timer
Post by arkestler »
How do I get the source of the Linux Driver?
Re: Watchdog Timer
Hello
You can find all the patches and their sources at the Compulab repositories which can be found here
http://www.fit-pc2.com/wiki/index.php/I ... nux_Mint_9
Return to “FreeBSD”
