no sound
shestero
no sound
Post by shestero »
Cannot produce any sound from my fit-PC2 under FreeBSD 8.2 R and KDE.
Everithing looks ok, but it remind silent. :cry:
I tried to connect my audio center (usually use it as a speaker system) and my headphones.
fitpc2-1# cat /dev/sndstat
FreeBSD Audio Driver (newpcm: 32bit 2009061500/i386)
Installed devices:
pcm0: <HDA Realtek ALC662 PCM #0 Analog> (play/rec) default
pcm1: <HDA Realtek ALC662 PCM #1 Digital> (play)
pcm2: <HDA Realtek ALC662 PCM #2 Analog> (rec)
shestero
Re: no sound
Post by shestero »
Note: The mixer ( xmixer ) works. I can turn on/off mic IN and even adjust left or right master channel volume. This I get know, because I can hear the subtle noice from the speakers.
But xmms and other applications produce no sounds! :(
tsdragon
Re: no sound
Post by tsdragon »
I am having the same problem...anyone have any ideas?
tsdragon
Re: no sound
Post by tsdragon »
is it possible to get the pin configuration set by BIOS for the audio device on the fit-pc2i? FreeBSD's snd_hda driver seems like all is good but no sound is coming out of my speakers and if i can get that pin configuration i can approach the writers of the driver for guidance since their driver can tweak such things on FreeBSD quite easily.
thanks,
albert
sfzhi
Re: no sound
Post by sfzhi »
I don't think the pin configuration set by BIOS would help you, because it is simply wrong (at least it was in my case, with the latest available BIOS version). See this thread for more details: http://www.fit-pc.com/forum/viewtopic.php?f=32&t=2420. Although that thread is mostly about Linux, you might find something useful there.
tsdragon
Re: no sound
Post by tsdragon »
thanks! that post was very helpful. i'm not 100% on the correctness of the following but i now have music coming out of my stereo speakers! :)
for those of you out there running FreeBSD 8.2 on this device put these lines at the bottom of your /boot/device.hints file:
hint.hdac.0.cad0.nid20.config=0x411111f0
hint.hdac.0.cad0.nid21.config=0x01014030
hint.hdac.0.cad0.nid22.config=0x411111f0
hint.hdac.0.cad0.nid24.config=0x01a19051
hint.hdac.0.cad0.nid25.config=0x411111f0
hint.hdac.0.cad0.nid26.config=0x01813050
hint.hdac.0.cad0.nid27.config=0x411111f0
hint.hdac.0.cad0.nid28.config=0x411111f0
hint.hdac.0.cad0.nid29.config=0x411111f0
hint.hdac.0.cad0.nid30.config=0x01441170
Return to “FreeBSD”
