hang on reboot - cpu_reset
fatsailor
Post by fatsailor »
This was covered in the linux side under this topic
http://www.fit-pc2.com/forum/viewtopic.php?f=9&t=301
FreeBSD 8.1 suffers the same problem. Unfortunately, the solution for Linux (placing reboot=b in the grub config) does not work with FreeBSD since it doesn't use grub nor does it have a reboot option with bootflags.
Given this problem happens under both Linux and FreeBSD - I suspect the BIOS. Has any of the dev's reproduced this? Status?
Mylife
Re: hang on reboot - cpu_reset
Post by Mylife »
Actually, for Linux users, the lastest kernels are now patched. We don't need "reboot=b" option anymore.
About the BIOS, the only thing Linux users have got to do is setting "Processor Full Speed" to "GV3 Only" in the BIOS.
But it's for another issue : http://www.fit-pc2.com/forum/viewtopic.php?f=9&t=361
I give this info even if not related because this other issue might also bother ... Otherwise ... No clue for *BSD. Sorry :cry:
arkestler
Post by arkestler »
@fatsailor, did you ever get this issue figured out? I have the same issue.
Return to “FreeBSD”
