display outputs
Chris.Smith
display outputs
Post by Chris.Smith »
Questions on the Airtop3 equipped with the integrated graphics/iGPU + GTX 1660:
  • I have 3 HDMI monitors I wish to connect to the iGPU side. The iGPU has two displayport 1.2 and one HDMI port. Can I use passive displayport to HDMI adapters for 2 of my monitors or do I need active adapters?
  • What ports are provided on the GTX 1660? In the Linus Tech Tips Airtop3 review video on youtube from 2019, it looked like 3xDisplayport and 1 type C port but on the website it looks like 4xDisplayport.
Andrey.Mazlin
Re: display outputs
Post by Andrey.Mazlin »
  • Onboard DP1 and DP2 ports support Display Port dual mode, and support DVI. You may use an active adapter it should work.
  • GTX 1660 has 3 DP and one HDMI port
Andrey Mazlin,
Useful links:
Chris.Smith
Re: display outputs
Return to “Airtop3 Hardware”
