Which Face Module option do I need to choose if I plan to use an Ethernet cable instead of wifi?
uptrend
Post by uptrend »
Would the default option of FM-AT3 [FMAT3] at $45.00 allow me to connect to the internet via an Ethernet cable?
If not, which option of the options do I need to choose?
Andrey.Mazlin
Re: Which Face Module option do I need to choose if I plan to use an Ethernet cable instead of wifi?
Post by Andrey.Mazlin »
uptrend wrote:
Sat Jul 04, 2020 7:24 pm
Hi, default configuration of Airtop3 device is - 2 GB Ethernet ports (see attached picture).
So - in order to use the Ethernet cable you don't need any FACE module.
airtop3 LAN ports.png (56.16 KiB) Viewed 433 times
Useful links:
https://fit-iot.com/web/
Support mil: fitpcsupport@compulab.co.il
Return to “Airtop3 Hardware”
