Airtop3 CPU and RAM question
uptrend
Post by uptrend »
tamir wrote:Answer remains the same for the Airtop2.
The successor for the Airtop2, the Airtop3 should be launched tomorrow, stay tuned:
https://fit-iot.com/web/products/airtop3/
Is there an option to buy the Airtop3 without the processor as well?
I remember Airtop1 had that option to just basically buy the case.
tamir
Re: I would be able to upgrade to the Intel Core i9-9980XE?
Post by tamir »
Unfortunately that option is not available for the Airtop3.
uptrend
Post by uptrend »
Regarding the Airtop3, would I be able to fit ECC RAM on it?
Also, is it possible to achieve 128GB RAM by (8 x 16 GB) instead of (4 x 32 GB)?
tamir
Re: Airtop3 CPU and RAM question
Post by tamir »
The Airtop3 has only 4 RAM slots, hence 4x32GB is the only option for 128GB configuration.
ECC is a feature supported by the CPU, unfortunately as of now, the Airtop3 is not offered with CPU that supports this feature.
uptrend
Post by uptrend »
So if I buy my own 4 x 32 GB ECC DDR4 RAM, would it work with the Core i9-9900K?
tamir
Post by tamir »
Unfortunatlely the i9-9900K does not support ECC RAM.
https://ark.intel.com/content/www/us/en ... 0-ghz.html
atang
Post by atang »
I'd like to know is there an option to use i7 9700T CPU?
tamir
Post by tamir »
atang wrote:I'd like to know is there an option to use i7 9700T CPU?
Unfortunately no, only the full clock version is available.
If you're looking for a lower wattage CPU, you could go with the Celeron available option G4900T rated for 35W.
uptrend
Post by uptrend »
https://www.amazon.com/2x64GB-DDR4-2666 ... 72&sr=8-16
Will the above, 2 x 64GB RAM, be compatible if I buy the Airtop 3 with the Xeon E-2288G Processor?
Another question:
Can the motherboard support 256 GB of RAM if I buy 4 of those 64GB sticks?
tamir
Post by tamir »
According to the product specs, Airtop3 supports up to 128GB of RAM:
https://fit-iot.com/web/products/airtop ... fications/
Considering the above, you'd better off going with 4x 32GB RAM for optimal usage of the memory channels.
Return to “General Airtop3 questions”
