(NOTE: The X scale in each of these graphs are NOT equal. Aida64's CPU usage has a faster update rate.)
The processor does get hot enough to thermal throttle, but it takes it 50 minutes to get there due to the sheer mass of cast aluminum in the case and the general efficiency of the cooling solution.
I admit I was a little disappointed because I was expecting to be able to run at 100% CPU utilization indefinitely while passively cooled.
Feedback for the Compulab team is that I wish there was an optional fan attachment. I can set up a desktop fan to blow on the case as needed, but it would not look nearly as elegant as what the Compulab mechanical engineers could fab.
