can it support 1920x1200?
Posted: Fri Jun 12, 2009 8:18 pm
by moolio
I have a 24' (1920x1200) LCD with DVI-D. Can fit-pc2 work with it?
Re: can it support 1920x1200?
Posted: Sat Jun 13, 2009 3:47 pm
Yes. fit-PC2 works at 1920x1200@60 Hz
Posted: Wed Jun 17, 2009 1:11 pm
by fitmir2
I try to connect fit-pc2 to my plasma Panasonic 42px80E with max resolution 1024x768 through hdmi.
http://www.panasonic.it/html/it_IT/Prod ... kInfo=true
Ubuntu pre-installed seems start ok but when X Server start after Ubuntu Splash Screen, the screen become blank (black).
What's wrong?
What's the pre-configured resolution in Ubuntu?
Posted: Fri Jul 31, 2009 12:44 am
by Spoon
Hi.
The Full-HD format of TVs is 1920x1080, not all chipsets support that.
Regards.
Posted: Tue Aug 18, 2009 10:44 pm
by MattW
What's the maximum resolution that the Fit-PC2 can support?
Posted: Wed Aug 19, 2009 10:11 am
Pixel clock on SDVO interface is 160MHz. That should be the limiting factor.
1920x1200@60Hz is confirmed to work. I have no indications on higher resolutions.
Posted: Thu Aug 20, 2009 5:46 pm
by MattW
I think you meant, 19
20x1200 (as 19
00x1200 is not a standard resolution)
Thanks for the feedback!
Posted: Thu Aug 20, 2009 6:02 pm
Typo corrected, thanks.
Posted: Sat Aug 22, 2009 5:00 pm
by ender
irads wrote:1920x1200@60Hz is confirmed to work. I have no indications on higher resolutions.
I had my Fit-PC2 connected to 30" Dell, with native resolution of 2560x1600, however Fit-PC2 allowed setting at most 1920x1200.
Posted: Sun Aug 23, 2009 10:37 am
2560x1600@60Hz requires a pixel clock of 245MHz. fit-PC2 supports up to 160MHz.
