Sony TV gives "unsupported signal" (solved, I think)
derek
Post by derek »
When I use my fit-PC2i with my Sony TV via HDMI (the intended display and connection for the fit-PC2i), the Sony TV gives "unsupported signal".
More specifically, with the computer connected to the TV via HDMI, at power on of the computer the TV says "1024x768" and I see the Energy Star / Intel Atom advertising screen and then during boot the TV says "640x480" while the computer shows "Linux Mint 9 . . . ." but later on the TV screen goes blank and the "unsupported signal" message comes up on the TV screen.
(I did not succeed in logging in "blind", which might well have worked, but this is not a long term option anyway.)
When connected via the fit-VGA adapter to the Sony TV (on its VGA input) the whole startup and login process works fine.
(continued...)
derek
Re: Sony TV gives "unsupported signal" (solved, I think)
Post by derek »
I surmised that the reason for the problem was that once X was running it was attempting to use a setting for graphics output that was not compatible with the TV - so as soon as X started, output was not possible.
Gleaned from another post in this forum, I did
apt-get install read-edid
read-edid | parse-edid
then editted /etc/X11/xorg.conf using some of the output from parse-edid.
Specifically,
In the section headed Section "Monitor" I added the two valid modes that parse-edid displayed as seemingly valid and in the section headed Section "Screen" I added
SubSection "Display"
Modes "1920x1080" "1280x720"
EndSubSection
"1920x1080" and "1280x720" are the (arbitrary) names of the modes defined in the earlier section.
derek
Post by derek »
I hope this helps somebody else but
Be warned: What I know about X and Linux fits (no pun intended) on the back of a postage stamp. I generally have to proceed using brute force and ignorance.
derek
Post by derek »
I noticed there's a typo in the above
should be
get-edid | parse-edid
monnier
Post by monnier »
derek wrote:When I use my fit-PC2i with my Sony TV via HDMI (the intended display and connection for the fit-PC2i), the Sony TV gives "unsupported signal".
If you're using a recent Linux kernel, it will include the gfx_psb module which knows how to set "any" video mode (including the right one), but IIUC that code does not yet know how to read/parse/use the EDID information from your monitor (check the "display driver" forum where there's a discussion about this), so it uses an arbitrary resolution, which might not be to your monitor's taste.
Return to “Display interface”
