Not loading/Screen issues
jose1
Post by jose1 »
Fit-PC2 XP
Stops at grey screen with the Intel logo, I press F2 stays on grey screen says loading...
(Loads OK with another screen)
jose1
Re: Not loading
Post by jose1 »
Original issue fixed. I Don't know if its something i did (bios>advanced>quickboot)
Now I'm having a new issue, I can't set the screen to full screen-864x1152 I can do larger and smaller.
fly
Re: Not loading/Screen issues
Post by fly »
XGA+ is a non-standard resolution/dimension. It was common once, but was never approved by any standardization organization like VESA. So some cards might simply not support this mode with out of the box.
Which operating system are you using?
Which driver are you using?
Can you select 1152x864?
jose1
Post by jose1 »
Win-XP SP3, Intel media accelerator driver (it gives me options ..-...634x1127 648x1152 720x1280...+..)Comp Works OK with other monitor. Monitor used to work OK with Fit-PC Slim(VGA) (Windows loading screen looks OK until Welcome screen)
fly
Post by fly »
fit-PC1 is a - from a technical point of view - entirely different system. Does this display work with the desired resolution on an other dvi or hdmi source?
This size works fine for me on linux, so it's not a hardware problem, but more likely a driver issue.
So, the fitPC2 dose work in the expected resolution with a different display?
What exactly does not work?
Did you get them from Intel, via Windows Update or from CompuLab? You might want to get the driver directly from CompuLab's download page.
I suggest you to install IEGD. It often supports more resolutions than GMA500 driver.
jose1
Post by jose1 »
The IEGD driver did the trick! Thanks!!
The original issue (Windows not loading) is caused by my wireless keyboard, I plug it out and Windows starts loading properly. Keyboard Works fine once its done loading.
Return to “Display interface”
