Fit-PC2 XP
Stops at grey screen with the Intel logo, I press F2 stays on grey screen says loading...
(Loads OK with another screen)
Not loading/Screen issues
Re: Not loading
Original issue fixed. I Don't know if its something i did (bios>advanced>quickboot)
Now I'm having a new issue, I can't set the screen to full screen-864x1152 I can do larger and smaller.
Re: Not loading/Screen issues
XGA+ is a non-standard resolution/dimension. It was common once, but was never approved by any standardization organization like VESA. So some cards might simply not support this mode with out of the box.
Which operating system are you using?
Which driver are you using?
Can you select 1152x864?
Win-XP SP3, Intel media accelerator driver (it gives me options ..-...634x1127 648x1152 720x1280...+..)Comp Works OK with other monitor. Monitor used to work OK with Fit-PC Slim(VGA) (Windows loading screen looks OK until Welcome screen)
fit-PC1 is a - from a technical point of view - entirely different system. Does this display work with the desired resolution on an other dvi or hdmi source?Monitor used to work OK with Fit-PC Slim(VGA)
This size works fine for me on linux, so it's not a hardware problem, but more likely a driver issue.full screen-864x1152
So, the fitPC2 dose work in the expected resolution with a different display?)Comp Works OK with other monitor.
What exactly does not work?(Windows loading screen looks OK until Welcome screen)
Did you get them from Intel, via Windows Update or from CompuLab? You might want to get the driver directly from CompuLab's download page.Intel media accelerator driver
I suggest you to install IEGD. It often supports more resolutions than GMA500 driver.
The IEGD driver did the trick! Thanks!!
The original issue (Windows not loading) is caused by my wireless keyboard, I plug it out and Windows starts loading properly. Keyboard Works fine once its done loading.
