fitlet2 + poe has a missing nic
Moderator: Andrey.Mazlin
alf
Post by alf »
I got a fitlet2 + poe, i should see a total of 3 nics..but on centos , i only see 2. (1x onboard + 1x poe)
lspci shows
01:00.0 Ethernet controller: Intel Corporation I211 Gigabit Network Connection (rev 03)
02:00.0 Ethernet controller: Intel Corporation I211 Gigabit Network Connection (rev 03)
any idea ? the 2nd onboard nic 'works' in that the switch will show blinking lights, but the nic itself has no lights.
tamir
Re: fitlet2 + poe has a missing nic
Post by tamir »
In order to check if the machine recognizes all NICs, please perform the following:
Connect your USB Flash Drive (UFD) to your computer and format it to FAT32 file system
Download and extract the BIOS UPDATER PACKAGE https://fit-pc.com/download/fitlet2/bio ... ackage.zip
The package contains the following files:
AfuEfix64.efi
Flash.nsh
Shellx64.efi
Startup.nsh
Copy the extracted files to the prepared UFD
Press the DEL key during the boot until the BIOS Setup appears
Browse to the Save & Exit menu
Click on the Launch EFI Shell from filesystem device option
At the EFI shell, type the commend "PCI".
Please take a picture of the output and post here.
It is also worth to check if it's an issue with CentOS's and check with the supported Linux mint on this machine, please consult the Linux mint installation guide - http://fit-pc.com/wiki/index.php?title= ... _Mint_19.1
Return to “fitlet2 FACET Cards”
