I'm interested in the fitlet2 pc to replace my current router.
For this, I would like to use the FITLET2-PARTS-FPCI card, but I'm not sure if it is possible to use all devices I would like
As software I I plan to use IPFire, maybe a different Linux based distribution. With the two LAN ports the main point is done. But as it is also possible to have the router as access point, I'll also add some WiFi cards.
With the FITLET2-PARTS-FPCI I cann add an M.2 SSD M-Key socket. The Intel WiFi card can work in AP mode, but isn't the best solution as I found in the internet. For this, I already bought a Compex WLE900VX miniPCIe card, which I could hopefully use in the miniPCIe-slot of the FACET card.
This Compex WLE900VX should be the AP for 5GHz WiFi.
But I would like to have also an AP for 2.4GHz WiFi, for this I could use a M.2 E-Key WiFi card SparkLAN WNFQ-158ACN(BT) or WNFQ-255ACN(BT). Both cards are M.2 with E-Key.
In the description of FITLET2-PARTS-FPCI I can see the following: FACET occupies both M.2 sockets of the SBC so it is not possible to install two storage devices or two WiFi cards.
Will this configuration work? Is there any restriction, so that only SSD+WiFi+3G/4G-Modem are working or should it be also possible to use SSD(M.2 M-Key)+WiFi(miniPCIe)+WiFi(M.2 E-Key)?
Here some links to the devices I would like to use:
- Compex WLE900VX: https://www.compex.com.sg/product/wle900vx/
- SparkLAN WNFQ-158ACN(BT): http://www.sparklan.com/p2-products-det ... 158ACN(BT)
- SparkLAN WNFQ-255ACN(BT): http://www.sparklan.com/p2-products-det ... 255ACN(BT)
Thanks & Best Regards,
Libor
