Hello together,
first of all I wish you all a happy new year.
Unfortunately I have the same problem as described above.
My Fitlet2 (FITLET2-CJ3455, S/N: 1171003-01742) won't recognize the Dual-LAN Facet-Card.
Can you please provide me the instructions to fix this problem?
Thank you very much.
Best regards
Sebastian
[SOLVED] fitlet2 does not recognize LAN FACET Card
Moderator: Andrey.Mazlin
Re: [SOLVED] fitlet2 does not recognize LAN FACET Card
- LAN_Test_Package_Results.jpg (2.94 MiB) Viewed 15865 times
Re: fitlet2 does not recognize LAN FACET Card
Here's the output. Thanks, Leonid.Leonid wrote:We need the screenshot with the output of the eeupdate64e application as described above.
edit: got the PM, thanks.
- 20180103_234557_resized.jpg (263.83 KiB) Viewed 15863 times
Hello,BastiL wrote:Hello together,
Best regards
Sebastian
I sent the private message with instructions how to program the blank LAN controllers.
Leonid Firdman
Hello,red wrote:Here's the output. Thanks, Leonid.Leonid wrote:We need the screenshot with the output of the eeupdate64e application as described above.
Leonid Firdman
Thanks! Problem solved.Leonid wrote:
01:00.0 Ethernet controller: Intel Corporation Device 1532 (rev 03)
02:00.0 Ethernet controller: Intel Corporation I211 Gigabit Network Connection (rev 03)
03:00.0 Ethernet controller: Intel Corporation I211 Gigabit Network Connection (rev 03)
04:00.0 Ethernet controller: Intel Corporation Device 1532 (rev 03)
the facet card seems to be unprogrammed.
Can you send me the instructions on how to do it?
Thank you
Thank you
Hello,js@jslz.de wrote:Hello,
Thank you
Leonid Firdman
unfortunately we have the same problem with our newly purchased fitlet2:
Using: Intel (R) PRO Network Connections SDK v2.25.20
EEUPDATE v5.25.20.03
Copyright (C) 1995 - 2015 Intel Corporation
Intel (R) Confidential and not for general distribution.
Warning: No Adapter Selected
NIC Bus Dev Fun Vendor-Device Branding string
1 1 00 00 8086-1532 Intel(R) I211 Blank OTP Device
2 2 00 00 8086-1539 Intel(R) I211 Gigabit Network Connection
3 3 00 00 8086-1539 Intel(R) I211 Gigabit Network Connection
4 4 00 00 8086-1532 Intel(R) I211 Blank OTP Device
Can you please send me the instructions how to flash the EEPROM?
Thank you!
Thank you!
Hello,consistec wrote:Hello,
Thank you!
Leonid Firdman
