serial port FreeBSD, PfSense
Moderator: Andrey.Mazlin
EduardCH
Post by EduardCH »
I'm trying to set up serial port as a local console on my PfSense setup on fitlet2. It looks like that it doesn't recognize local serial port. Is it possible to make it work? Serial works fine in POST and BIOS.
thomask
Re: serial port FreeBSD, PfSense
Post by thomask »
EduardCH wrote:
Sun Nov 22, 2020 9:32 am
Hi Eduard,
What pfSense installer did you use? Or is pfSense already installed?
I came across the same question while trying to get serial output working for Ubuntu 20.04. Since serial console always worked out of the box with pfSense I booted up the pfSense installer (pfSense-CE-memstick-serial-2.4.5-RELEASE-p1-amd64). And I didn't get it to work either but got it to mostly working with Ubuntu but with tweaking. With Fedora 33 it worked out of the box. As mentioned in a wiki entry from Compulab in Linux the serial port is ttyS6 not ttyS0 as it is usually.
My take of it is: Since it happens after the BIOS gives control over to the OS, it's an OS issue and Compulab can't do much. Open an issue with FreeBSD/pfSense would be your best option.
It's most likely an issue with OS support for "Celeron N3350/Pentium N4200/Atom E3900 Series HSUART Controller" which handles the serial console.
I tried setting the serial console manually in the pfSense installer (press '3' in the installer menu) but it didn't help. What I tried:
set boot_serial=YES
set comconsole_speed=115200
set comconsole_port="0x3f8"
set hw.uart.console="io:0x3f8,br:115200"
set console=comconsole
In theory you could also set which PCI device is used for the serial console but in my case the setting go rejected. It also got rejected in Linux but there you can force it... but not for pfSense/FreeBSD.
How to (unsuccessfully) set the serial console PCI device:
set comconsole_pcidev="0:0:0x18:2"
Maybe some of the information above can be of help
/Thomas
jlduran
Post by jlduran »
You could use the serial console on FreeBSD by setting in /boot/loader.conf:
hw.uart.console="mm:0xfea10000,rs:2"
This will configure the memory-mapped serial console.
The base address is obtained by issuing:
# pciconf -l -b pci0:24:2
uart2@pci0:0:24:2:	class=0x118000 rev=0x0b hdr=0x00 vendor=0x8086 device=0x5ac0 subvendor=0x8086 subdevice=0x7270
    bar   [10] = type Memory, range 64, base 0xfea10000, size 4096, enabled
    bar   [18] = type Memory, range 64, base 0, size 4096, enabled
From uart_subr.c:
The specification is a list of attributes
separated by commas. Each attribute is a tag-value pair with the tag and
value separated by a colon. Supported tags are:
	bd = Busy Detect
	br = Baudrate
	ch = Channel
	db = Data bits
	dt = Device type
	io = I/O port address
	mm = Memory mapped I/O address
	pa = Parity
	rs = Register shift
	sb = Stopbits
	xo = Device clock (xtal oscillator)
The io and mm tags are mutually exclusive.
Return to “fitlet2 software”
