Intel Graphic driver update - 3D?
Mikael63
Post by Mikael63 »
On my MintBox Mini 2 Pro, running Draftsight https://www.3ds.com/products-services/d ... -download/ all handles is very slow.
On my former PC with Nvidia this also occurs but changing driver to (like) "Nvidia experimental support for 3D" it works fine.
How to do similar for my Mintbox?
I've follow this: http://fit-pc.com/wiki/index.php/Intel: ... ux_Mint_19 and also checked it again.
Linux Mint 19.1 -64 Cinnamon+MATE
Note: I'm not using 3D in Draftsight, just 2D.
Linux Mint Tricia (19.3) Cinnamon @ MBM2 Pro
tamir
Re: Intel Graphic driver update - 3D?
Post by tamir »
Linux mint has been update to 19.1 "Tessa" and the fit-pc wiki link has been changed to:
http://fit-pc.com/wiki/index.php?title= ... _Mint_19.1
Have you went through "Intel video acceleration graphic drivers" section?
Mikael63
Post by Mikael63 »
Yes, I believe it was exact the same command for Mint 19 as for Mint 19.1.
tamir
Post by tamir »
The slowness you exhibit is only in Draftsight?
Have you tried an alternative 2D SW?
Mikael63
Post by Mikael63 »
Other much "easier" softfware works.
Running Bricscad for Windows in a virtualbox-machine also works fine.
tamir
Post by tamir »
That pretty much eliminates issues with the platform itself.
I suggest you to contact the SW vendor for support on this case.
Mikael63
Post by Mikael63 »
Well, yes.. but when using Bricscad in native Linux there is huge flickering on the screen when let say drawing a line.
Starting from terminal gives:
mint@mint-fitlet2 ~ $ bricscadv13
Gtk-Message: 20:56:33.237: Failed to load module "gail"
Gtk-Message: 20:56:33.238: Failed to load module "atk-bridge"
(bricscad:17299): Gtk-WARNING **: 20:56:33.253: Kan inte hitta temamotorn i "module_path": "murrine",
(bricscad:17299): Gtk-WARNING **: 20:56:33.254: Kan inte hitta temamotorn i "module_path": "clearlooks",
(bricscad:17299): Gtk-WARNING **: 20:56:33.254: Kan inte hitta temamotorn i "module_path": "murrine",
(bricscad:17299): Gtk-WARNING **: 20:56:33.255: Kan inte hitta temamotorn i "module_path": "murrine",
(bricscad:17299): Gtk-WARNING **: 20:56:33.256: Kan inte hitta temamotorn i "module_path": "murrine",
(bricscad:17299): Gtk-WARNING **: 20:56:33.257: Kan inte hitta temamotorn i "module_path": "clearlooks",
(bricscad:17299): Gtk-WARNING **: 20:56:33.257: Kan inte hitta temamotorn i "module_path": "murrine",
(bricscad:17299): Gtk-WARNING **: 20:56:33.258: Kan inte hitta temamotorn i "module_path": "murrine",
(bricscad:17299): Gtk-WARNING **: 20:56:33.259: Kan inte hitta temamotorn i "module_path": "murrine",
(bricscad:17299): Gtk-WARNING **: 20:56:33.260: Kan inte hitta temamotorn i "module_path": "murrine",
(bricscad:17299): Gtk-WARNING **: 20:56:33.261: Kan inte hitta temamotorn i "module_path": "murrine",
(bricscad:17299): Gtk-WARNING **: 20:56:33.262: Kan inte hitta temamotorn i "module_path": "murrine",
(bricscad:17299): Gtk-WARNING **: 20:56:33.263: Kan inte hitta temamotorn i "module_path": "murrine",
Return to “fitlet2 software”
