Bios Settings for USB Boot
schling
Post by schling »
I am going nuts trying to figure out how to boot from USB in order to install Windows 10 from a pen drive on my FItlet2. The drive I am using is a SanDisk Cruzer Edge and I have checked on an older Lenovo ThinkPad that is boots correctly into the installation screen.
So far what I have done is to:
- Set CSM Support to enabled (to avoid being stuck forever in the BIOS screen)
- Set SanDisk (the BIOS seems to recognise the drive) as Boot Option #1
- Enable Fast Boot and USB Support to Full Initial
The version is 2.18.1263 Copyright C 2017 American Megatrends Inc
Thanks for any help
Robert
tamir
Re: Bios Settings for USB Boot
Post by tamir »
Please check the following BIOS config:
Chipset -> South Bridge -> OS Selection
Should be on [Windows]
See if that works
schling
Post by schling »
Thanks .... it was already on Windows and I just get a black screen after the Compulab Filtlet2 splash screen.
schling
Post by schling »
For the benefit of others: I was trying to install Windows 10 32bit and discovered that this is not possible in UEFI mode. Had no problems with 64bit.
Return to “fitlet2 software”
