Reboot issue
Moderator: Andrey.Mazlin
Ekkawith.Hiranaburna
Reboot issue
Post by Ekkawith.Hiranaburna »
Hi Support Team,
I have 10pcs of Fitlet2, that some of them has weird reboot behavior.
I installed Ubuntu 18.04.5 LTS (GNU/Linux 4.15.0-177-generic x86_64)
Sometime ,when I command fillet to reboot by "shutdown -r now"
fitlets go to shutdown process but it doesn't reboot properly.
furthermore, led on powerbutton turn off and fillet doesn't boot after I push power button.
for poweron fillet2. I have to pull adapter off from fitlet2 and connect it again.
I also made script to test this issue by reboot fitlet2 every 10 minute.
after 200 times of reboot , 3 of 10 always have this issue.
Do you have this kind of issue and what can I do to solve this issue?
Thank you in advance
Andrey.Mazlin
Re: Reboot issue
Post by Andrey.Mazlin »
As far as I know you've also sent this to our support box.
So the correspondence will be continued there.
Useful links:
https://fit-iot.com/web/
Return to “fitlet2 hardware”
