FC-PCI GPIO
Moderator: Andrey.Mazlin
Yendor
FC-PCI GPIO
Post by Yendor »
FInal got my Fitlet 2 with FC-PCI card and am trying to see if will work with a RAK2247 Lora Concentrator, currently up to trying to reset the card via pin 22 using 'sys/class/gpio', but can not find any documentation on the PCI slot of the FC_PCI card.
I did find FC-PCI fitlet2 FACET Pinout description table but it only list the M.2 slot (Unless I'm reading it wrong).
Can anyone provide information on the PCI pinout and there mapping to the GPIO's?
tamir
Re: FC-PCI GPIO
Post by tamir »
You should be able to find the schematic files of the FC-PCI at the following link:
http://fit-pc.com/wiki/index.php?title= ... rds#FC-PCI
Yendor
Re: FC-PCI GPIO
Post by Yendor »
Thanks for the reply Tamir,
What I am looking for is the GPIO number attached to the WIFI_RST# line as I need to control that pin via the /sys/class/gpio/gpio$WIFI_RST_PIN.
Just like the front led example on the wiki http://fit-pc.com/wiki/index.php?title= ... front_LEDs
the script I want to run is:
#!/usr/bin/env bash
# change pin
IOT_SK_SX1301_RESET_PIN=436 # Front Yellow LED 1, Change to GPIO of mPCI pin 22.
echo "Accessing concentrator reset pin through GPIO$IOT_SK_SX1301_RESET_PIN..."
WAIT_GPIO() {
    sleep 0.1
iot_sk_init() {
    # setup GPIO
    echo "$IOT_SK_SX1301_RESET_PIN" > /sys/class/gpio/export; WAIT_GPIO
    # set GPIO as output
    echo "out" > /sys/class/gpio/gpio$IOT_SK_SX1301_RESET_PIN/direction; WAIT_GPIO
    # write output for SX1301 reset
    echo "1" > /sys/class/gpio/gpio$IOT_SK_SX1301_RESET_PIN/value; WAIT_GPIO
    echo "0" > /sys/class/gpio/gpio$IOT_SK_SX1301_RESET_PIN/value; WAIT_GPIO
    # set GPIO as input
    echo "in" > /sys/class/gpio/gpio$IOT_SK_SX1301_RESET_PIN/direction; WAIT_GPIO
iot_sk_term() {
    # cleanup GPIO
    if [ -d /sys/class/gpio/gpio$IOT_SK_SX1301_RESET_PIN ]
    then
        echo "$IOT_SK_SX1301_RESET_PIN" > /sys/class/gpio/unexport; WAIT_GPIO
    fi
iot_sk_term
iot_sk_init
sleep 3
./lora_pkt_fwd
Yendor
Re: FC-PCI GPIO
Post by Yendor »
While waiting on some answers, I’ve been digging and found the fitlet2 blocks diagram PDF and having a guess that one of the pcie block should be connected to the mPCIe on the FC-PCI card.
I went looking at the Intel datasheet PDF for the E3950 and found that the PCIe is the same as the N- and J- series processors. So off too the N- and J- series datasheets.
Now looking at N- and J- series datasheets (334817-001), we find in table 2-18, PCIE_PERST[3:0]_N, type GPIO, with note: "Operates in GPIO Mode, These signal need to be assigned by BISO based on design implementation".
don't know where to go from there?
did a dump with lspci -v and got 2 PCI bridge:
00:13.0 PCI bridge: Intel Corporation Celeron N3350/Pentium N4200/Atom E3900 Series PCI Express Port A #2 (rev fb) (prog-if 00 [Normal decode])
        Flags: bus master, fast devsel, latency 0, IRQ 120
        Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
        I/O behind bridge: 0000e000-0000efff
        Memory behind bridge: c1100000-c11fffff
        Capabilities: [40] Express Root Port (Slot+), MSI 00
        Capabilities: [80] MSI: Enable+ Count=1/1 Maskable- 64bit-
        Capabilities: [90] Subsystem: Device 0000:0000
        Capabilities: [a0] Power Management version 3
        Capabilities: [100] #00
        Capabilities: [140] Access Control Services
        Capabilities: [150] Precision Time Measurement
        Capabilities: [200] L1 PM Substates
        Kernel driver in use: pcieport
        Kernel modules: shpchp
00:13.2 PCI bridge: Intel Corporation Celeron N3350/Pentium N4200/Atom E3900 Series PCI Express Port A #3 (rev fb) (prog-if 00 [Normal decode])
        Flags: bus master, fast devsel, latency 0, IRQ 121
        Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
        I/O behind bridge: 0000d000-0000dfff
        Memory behind bridge: c1000000-c10fffff
tamir
Re: FC-PCI GPIO
Post by tamir »
Our R&D are investigating this.
I will return to you asap.
tamir
Re: FC-PCI GPIO
Post by tamir »
Our R&D determined that FPCI P5-22 (WIFI_RST#) is not controlled by GPIOs
But theoretically you could use other lines:
FPCI P5-20 (W_DISABLE#)
FPCI P4-54 (W_DISABLE2#)
If the above could be suitable, we could work to get you the information.
Yendor
Re: FC-PCI GPIO
Post by Yendor »
Thanks Tamir,
Can you confirm with R&D that the WIFI_RST# is pull down (low), as I might be able to reset the card via the USB interface but pin22 need to be low.
would be a big disappointment if I can't use the mPCIe for this card as the Fitlet2 is performing beyond expectations.
Thanks again for your help.
tamir
Re: FC-PCI GPIO
Post by tamir »
I'll confirm that with our R&D and get back to you.
tamir
Re: FC-PCI GPIO
Post by tamir »
our R&D replied that the WIFI_RST# pin is controlled directly by the SoC and should have a pull down but we cannot control.
Return to “fitlet2 hardware”
