Fitlet processor
Moderators: Andrey.Mazlin, Andrey.Mazlin
sumdumguy
Fitlet processor
Post by sumdumguy »
I am looking at a Fitlet as a possible replacement/substitution for an Automation product I currently use a lot - but that is a little flimsy in it's construction and has only a 1yr warranty. Most of the specifications are pretty straightforward, but I am having trouble finding comparative data on the processors - theirs and yours. I was wondering if someone who swims in these circles would have anything to share that might help clear this up.
I have the listed specifications below - I am looking at the processor specifically.
HARDWARE SPECIFICATIONS
TI AM3352: 1000MHz ARM® Cortex™-A8
1GB DDR3 SDRAM
Removable micro-SD card with 4GB flash total storage/2GB user storage
*Wi-Fi (Client or WAP) IEEE802.11a/b/g/n IEEE802.11n HT20 @ 2.4GHz IEEE802.11n HT20/HT40 @ 5GHz Configurable radio (Off, WAP, or Client) WPAPSK/WPA2PSK supported
*USB type A connector - Back-up and restore support
(2) isolated RS-485 with selectable bias and termination
(2) 10/100MB Ethernet ports
**Supply requirements: 24VAC rated
at 24VA minimum, or 24VDC rated at
1A (24W) minimum
I see the Fitlet has 3 processor options - I wanted to know generally how they compare.
Atom x7-E3950 [CE3950]
Celeron J3455 [CJ3455]
Atom x5-E3930 [CE3930]
There will be a bit of a performance penalty as I would need to run a full windows install to support the software involved, and the other device does not do that (it runs QNX) - I understand that. I am just trying to get a feel for the one spec I cannot find a quick correlation for out of the list I pasted above.
I appreciate your taking the time to respond. :D
tamir
Re: Fitlet processor
Post by tamir »
Performance wise, the Celeron has better performance per Watt.
The CPU comparison is available at:
https://ark.intel.com/content/www/us/en ... 6488,95594
sumdumguy
Post by sumdumguy »
That is a good comparison of 2 chips you all offer - but there is nothing on the other devices chip:
I had a VERY hard time finding info on it - I figured you all had heard of it or declined using it or had something on it.
Alll I can find quickly is that it is not an Intel chip (it would be super swell to include it in the side by side comparison you put together - very nice. and that it is 32bit and the 2 you included in your link are both 64bit.
Now that I see the 'Notify me when a reply is posted' button, I will be more prompt in responding. Most forums I visit do not require a checkbox for notifications.
tamir
Post by tamir »
TI AM3352: 1000MHz ARM® Cortex™-A8 is used in BeagleBone.
You can find useful comparison information at the following article:
https://www.phoronix.com/scan.php?page= ... inux&num=3
sumdumguy
Post by sumdumguy »
Extract from that link:
The BeagleBone Black might be useful for specialized embedded use-cases or penny-pinching Linux hobbyists, but for any real ARM Linux development use or desktop experiments, it's far too slow. I can't find any use-case myself for the BeagleBone Black as it's far too slow for any worthwhile code testing or performance monitoring; this low-end ARM development board might just be best served by making it another creative computer beer bottle opener.
A less than positive review. Thank you for digging that up. It was VERY helpful.
TomT
Post by TomT »
sumdumguy wrote:I see the Fitlet has 3 processor options - I wanted to know generally how they compare.
In my opinion, the Atoms are a good choice if you need graphics, and the Celeron is best for other purposes.
The higher-spec Atom is kind of the best of both worlds, but it runs a little hotter under load and can therefore be subject to throttling. The Celeron pretty much runs stone-cold, max I've seen it reach is 52C at ambient room temp with the standard fitlet2 top cover.
Return to “fitlet2 hardware”
