firewall hardware?
Moderator: Andrey.Mazlin
TrevorNoah
firewall hardware?
Post by TrevorNoah »
hi all,
I would like to get started with opensense/pfsense and don't really know what kind of machines I should get that on.
I have a 200/20 connection and would like to run 1 or 2 vpn above that that. Energy is costly in Belgium (0.24€/kwh) and so I'm not that much inclined to get enterprise hardware such as a R210ii that is often recommended here.
tamir
Re: firewall hardware?
Post by tamir »
Although Linux mint is the only fully supported distribution for the fitlet2, there are customers reports it works well with it.
Perhaps you could consult the pfsense community via:
https://forum.netgate.com/
Also, there are threads over pfsense configuration for the fitlet2. A short search in here resulted the the following:
https://fit-pc.com/forum/viewtopic.php? ... nse#p21743
Ztarp
Post by Ztarp »
I'm running a Fitlet2 with J3455, 128GB M.2 SSD, and 8GB RAM and Opnsense. Works fine.
Ztarp
Post by Ztarp »
There's also a lot of discussion of the Fitlet2 running various firewalls here: https://bbs.io-tech.fi/threads/tee-se-i ... hto.14625/. You may have to use Google translate.
Ztarp
Post by Ztarp »
Speed testing on 1GB connection using Sophos XG and pfSense (?) with and without Suricata IPS: https://bbs.io-tech.fi/threads/palomuur ... lle.74958/
Return to “fitlet2 hardware”
