Hey fit-iot,
I'm experiencing an issue with my fitlet 2. I have a known working fitlet2 and fc-pci card populated with an intel 8265 wifi card. I have removed the 8265 and tried using a 9260 (tested working in another machine) and only the bluetooth component populates, no output is provided from lspci or dmesg to indicate that a wifi component is even plugged in. I'm running kernel version 4.20.8 and have the 9260 driver installed, but I would not expect those to have any bearing on the card being detected as installed. Is there a compatibility issue here?
Regards,
kwitiii
M.2 wifi compatibility
Moderator: Andrey.Mazlin
Re: M.2 wifi compatibility
We haven't tested the Intel 9260AC, but we have heard from customers that the following might work:
The cause of this issue is probably due to the inability to choose the right PCI interface speed
• PCI setting for Gen2 and De-emphasis in BIOS
Some platforms experience difficulties enumerating the Wi-Fi device after warm boot. The cause of this issue is the ability to choose the right PCI interface speed (Gen1/2). A fix for this issue is to disable the PCI De-emphasis option in the BIOS and set speed to Gen2.
1. De-emphasis disabled.
2. Speed – AUTO (to allow Gen2 speed).
Thank you tamir! I can confirm in my fitlet2 CE3930 that disabling the de-emphasis option of the BIOS has allowed my Intel 9260AC wifi/BT module to properly initialize during boot, whereas only BT would work properly before the change. I found the setting(s) buried in the BIOS under Chipset>South Cluster Configuration>PCI Express Configuration>PCI Express Root Port 3>PCIe Selectable De-emphasis>Disable in order to get the wifi to properly initialize under Ubuntu 18.04.1 LTS which apparently is running a kernel with the proper iwlwifi drivers from Intel to work with the Intel 9XXX wifi/BT modules.
The speed was already set to Auto in my case so I did not need to make any changes there. I confirmed that PCI Express Root Port 3 was the only one that needed to have the de-emphasis setting changed in my case with the Intel wifi module installed in the FC CEM fitlet card in the M.2 E key socket as recommended by the installation instructions: http://www.fit-pc.com/wiki/index.php?ti ... structions
Hope this will help someone else looking to integrate one of the newer Intel wifi/BT modules in a fitlet2.
Now I just wait for BlueZ to add better support for Bluetooth 5 features like LE coded PHY and I'll be in great shape!
Jeff
Jeff
Good news, glad this worked out well for you.
For my CJ3455 with an FC-CEM and Intel 9260, this workaround was not sufficient for stability. The fitlet could detect the 9260, setting it to Gen2 speed (confirmed with lspci -vv -s 01:00), but it fails over time with various PCIe commands timing out.tamir wrote:The cause of this issue is the ability to choose the right PCI interface speed (Gen1/2). A fix for this issue is to disable the PCI De-emphasis option in the BIOS and set speed to Gen2.
I believe the issue is signal integrity, especially through the two connectors routing to the FC-CEM. An Intel 8260 (a PCIe Gen1 device) works just fine.
My workaround is to set the Speed to Gen1, leaving BIOS de-emphasis setting at the default. The 9260 is detected and runs stably. The reduced speed is really not a problem, since the #3 root port is not shared, and gets roughly 2000Mbit/s, adequate for the AC1750 max rate of the device.
See LinkCap, LnkSta and LnkSta2 in the stable configuration:
# lspci -vv -s 01:00
01:00.0 Network controller: Intel Corporation Wireless-AC 9260 (rev 29)
Subsystem: Intel Corporation Wireless-AC 9260
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0, Cache Line Size: 64 bytes
Interrupt: pin A routed to IRQ 22
Region 0: Memory at c1200000 (64-bit, non-prefetchable) [size=16K]
Capabilities: [c8] Power Management version 3
Flags: PMEClk- DSI+ D1- D2- AuxCurrent=0mA PME(D0+,D1-,D2-,D3hot+,D3cold+)
Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=0 PME-
Capabilities: [d0] MSI: Enable- Count=1/1 Maskable- 64bit+
Address: 0000000000000000 Data: 0000
Capabilities: [40] Express (v2) Endpoint, MSI 00
DevCap: MaxPayload 128 bytes, PhantFunc 0, Latency L0s <512ns, L1 unlimited
ExtTag- AttnBtn- AttnInd- PwrInd- RBE+ FLReset+ SlotPowerLimit 0.000W
DevCtl: CorrErr- NonFatalErr- FatalErr- UnsupReq-
RlxdOrd+ ExtTag- PhantFunc- AuxPwr+ NoSnoop+ FLReset-
MaxPayload 128 bytes, MaxReadReq 128 bytes
DevSta: CorrErr- NonFatalErr- FatalErr- UnsupReq- AuxPwr+ TransPend-
LnkCap: Port #0, Speed 5GT/s, Width x1, ASPM L1, Exit Latency L1 <8us
ClockPM+ Surprise- LLActRep- BwNot- ASPMOptComp+
LnkCtl: ASPM L1 Enabled; RCB 64 bytes Disabled- CommClk+
ExtSynch- ClockPM+ AutWidDis- BWInt- AutBWInt-
LnkSta: Speed 2.5GT/s (downgraded), Width x1 (ok)
TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
DevCap2: Completion Timeout: Range B, TimeoutDis+, NROPrPrP-, LTR+
10BitTagComp-, 10BitTagReq-, OBFF Via WAKE#, ExtFmt-, EETLPPrefix-
EmergencyPowerReduction Not Supported, EmergencyPowerReductionInit-
FRS-, TPHComp-, ExtTPHComp-
AtomicOpsCap: 32bit- 64bit- 128bitCAS-
DevCtl2: Completion Timeout: 16ms to 55ms, TimeoutDis-, LTR+, OBFF Disabled
AtomicOpsCtl: ReqEn-
LnkCtl2: Target Link Speed: 5GT/s, EnterCompliance- SpeedDis-
Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
Compliance De-emphasis: -6dB
LnkSta2: Current De-emphasis Level: -3.5dB, EqualizationComplete-, EqualizationPhase1-
EqualizationPhase2-, EqualizationPhase3-, LinkEqualizationRequest-
Capabilities: [80] MSI-X: Enable+ Count=16 Masked-
Vector table: BAR=0 offset=00002000
PBA: BAR=0 offset=00003000
Capabilities: [100 v1] Advanced Error Reporting
UESta: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UEMsk: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UESvrt: DLP+ SDES+ TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
CESta: RxErr- BadTLP- BadDLLP- Rollover- Timeout- AdvNonFatalErr-
CEMsk: RxErr- BadTLP- BadDLLP- Rollover- Timeout- AdvNonFatalErr+
AERCap: First Error Pointer: 00, ECRCGenCap- ECRCGenEn- ECRCChkCap- ECRCChkEn-
MultHdrRecCap- MultHdrRecEn- TLPPfxPres- HdrLogCap-
HeaderLog: 00000000 00000000 00000000 00000000
Capabilities: [14c v1] Latency Tolerance Reporting
Max snoop latency: 3145728ns
Max no snoop latency: 3145728ns
Capabilities: [154 v1] L1 PM Substates
L1SubCap: PCI-PM_L1.2+ PCI-PM_L1.1+ ASPM_L1.2+ ASPM_L1.1+ L1_PM_Substates+
PortCommonModeRestoreTime=30us PortTPowerOnTime=18us
L1SubCtl1: PCI-PM_L1.2+ PCI-PM_L1.1+ ASPM_L1.2+ ASPM_L1.1+
T_CommonMode=0us LTR1.2_Threshold=163840ns
L1SubCtl2: T_PwrOn=18us
Kernel driver in use: iwlwifi
Kernel modules: iwlwifi
Good work on working this out @TomT, and thank you for sharing. I'm sure this could be useful for other users.
I am trying to make my 4G M2 card based on chipset EM7455 to work with my fitlet2 but I am unable to make it recognize properly.
In another computer it is directly recognized and initiated correctly unders /dev/ttyUSB0.
Here I got a partially recognized device but missing some steps (the latest) to make it available to interact with Linux.
On my working computer :
On fitlet2 :
I am wondering if I should play with some parameters like you guys for the Wireless card ?
I tried the Speed to Auto / Gen1 and the De-emphasis disabled but still the same issue..
Many thanks
usbcore: registered new interface driver usbserial
usbcore: registered new interface driver usbserial_generic
usbserial: USB Serial support registered for generic
usbcore: registered new interface driver qcserial
usbserial: USB Serial support registered for Qualcomm USB modem
usb 1-6: Qualcomm USB modem converter now attached to ttyUSB0
Many thanks
