fitlet2: mini serial port pinout
Moderator: Andrey.Mazlin
mytest
Post by mytest »
Where can I find the pinout of the mini serial connector (RS232) ?
tamir
Re: fitlet2: mini serial port pinout
Post by tamir »
The Pinout for the RS232 default port in the fitlet2 is as follows:
1 - COM1_TX
2 - COM1_RTS
3 - COM1_RX
4 - COM1_CTS
5 - X
6 - X
7 - X
8 - GND
mytest
Post by mytest »
thanks!
Where can I find the pin layout and the connector reference?
I believe it is a mini B USB, but is not really sure
Mikael63
Post by Mikael63 »
It is an ultra-mini serial port
see
https://fit-iot.com/web/product/rs232-adapter/
(changed link)
mytest
Post by mytest »
Yes, this I've already understood from the doucmentation.
For my I application, I will need to make my own cabling.
Any hints on connector reference are welcome
tamir
Post by tamir »
mytest wrote:Yes, this I've already understood from the doucmentation.
Sent a PM with more info of the adapter cable
mytest
Post by mytest »
MrMathMo
Post by MrMathMo »
Hi tamir,
I'm also looking for more info. If you can also PM me.
I lost my cable and can't find where to buy a new one without being crazy expensive.
I'll try to solder some wires.
Best regards
Sent from my Pixel 2 XL using Tapatalk
tamir
Post by tamir »
MrMathMo wrote:Hi tamir,
Best regards
Sent PM
kwitiii
Post by kwitiii »
Can I also get this info? Thanks!
Return to “fitlet2 hardware”
