Fitlet3
Posted: Tue Feb 08, 2022 7:17 pm
I see the Fitlet3 is available for order.
Whats the performance difference between x6425E, J6412 and x6211E? And how do they compare with Fitlet2 generation CPUs? I'm currently using a Fitlet2 with J3455 but need a second Fitlet for a new location.
I am currently running OpnSense 22.1 (FreeBSD 13) on my Fitlet2 and plan to run OpnSense on Fitlet3. Will this be similar to Fitlet2, "not supported officially by Compulab" but should work?
Added 2/10:
I'd been looking at the datasheet specs earlier but I see in the specifications posted at https://fit-iot.com/web/products/fitlet ... fications/ state: "Compatible with other hypervisors and operating systems (e.g. ESXi, FreeBSD)"
Are the RAM details correct at the specifications URL above? The datasheeet just states "SO-DIMM DDR4 up to 3200MT/s" but the specifications state "1x SO-DIMM 204-pin DDR4 Non-ECC DDR4-3200MT/S (1.35V)". Isn't DDR4 SO-DIMM 260-pin and 1.2V? I think 204-pin is probably a typo or carried over from old Fitlet2 DDR3 specs.
Some CPU benchmarks for what they are worth. Note low number of samples on newer processors: https://www.cpubenchmark.net/compare/In ... 4474vs4347
Added 2/10:
