Current best hardware for reasonable VPN and no fan?
Moderator: Andrey.Mazlin
TrevorNoah
Post by TrevorNoah »
I have a 320Mbit/s fibre connection at home, and would like to be able to use it all for VPN capability as I tend to move large VMs between home and datacentre.
However, I don't want to have a hot, noisy PC running my pfsense. Hardware is evolving all the time, so i'd like to know what's the current view on what CPU I should be aiming for to get the most out of my VPN connection whilst hopefully running a fanless pre-built box?
I don't necessarily only need suggestions for current pfsense hardware, I'd like to know what CPUs would hit that performance spot (and what won't!) and what I should be looking for in terms of crypto hardware to aid me. It doesn't matter whether it's IPSec or OpenVPN as I can run either.
tamir
Re: Current best hardware for reasonable VPN and no fan?
Post by tamir »
Although Linux mint is the only fully supported distribution for the fitlet2, there are customers reports it works well with it.
Perhaps you could consult the pfsense community via:
https://forum.netgate.com/
Also, there are threads over pfsense configuration for the fitlet2. A short search in here resulted the the following:
https://fit-pc.com/forum/viewtopic.php? ... nse#p21743
