MintBox network trouble at launch
Moderator: Andrey.Mazlin
Hello with a warning. I am not at all an expert on this.
I got on Friday a MintBox Mini2 Pro. Everything has been connected without a hitch with the exception of the network.
I am writing from my old laptop, with Linux Mint, connected via ethernet cable to a Devolo powerline extension of the cable modem. When I try to do the same in each of the MintBox ports, I get disconnected and the message: cable unplugged. When I try to connect wireless, it detects the network, I put in the password and it disconnects.
I have tried different cables and it doesn't work. Various devices are connected in the house at present and in the past, with Linux or other OS.
Anyone has a suggestion to sort out this issue? I would appreciate very much your help.
Re: MintBox network trouble at launch
Does the behavior changes when you connect the MBM2 directly to the cable modem ?
Thank you for your interest, Tamir.
Yes. I did check on Saturday and I have done it again after reading your post. I have connected the ethernet cable to the modem and I got the same 'cable unplugged' message. On wireless the same refusal to connect, with 100% signal reception by the modem.
Thank you for your reply, I see that you've already contacted us by email but since we are already corresponding here, I'll continue unless you'd choose otherwise.Ignatius wrote:Thank you for your interest, Tamir.
Does this behavior seen on both Ethernet ports?
I'd suggest you to try the following:
1. See if you get the same behavior with Linux mint Live USB
2. Update Kernel
3. Restore default on BIOS:
http://www.fit-pc.com/wiki/index.php/Fi ... leshooting
4. Re-install Linux mint - http://www.fit-pc.com/wiki/index.php/In ... ux_Mint_19
Thank you, Tamir.
I will have no time today or tomorrow to work on this. I will post a reply when I have done what you suggest.
I gave it a go today, Tamir.
I do not know how to update the kernel without connection but I tried with a live usb, I restored defaults in BIOS and finally installed Linux Mint 19 again. But no change. The interfaces for network connections are all down.
I am sending you this from a laptop with Linux Mint 17.3. All is connected to the same router and never had trouble. I am a bit lost about what to do next.
Thank you for your advice.
I.
I.
Please provide a dmesg log from the shell.
Also try to update the machine BIOS to the latest by following the below guide:
http://fit-pc.com/wiki/index.php/Fitlet2:_BIOS_Update
Just a small note, about disabled wireless at startup.
At the beginning, with this issue, I used
and/or
Above can help, but the solution for me was:
https://www.fosslinux.com/2561/how-to-d ... x-mint.htm
Note: "seahorse" is in LM19 Cinnamon called "Passwords and keys" (translated back from Swedish)
sudo service network-manager restart
sudo service network-manager stop
sudo service network-manager start
Step 1) Launch ‘Terminal’ and enter the following command. Elementary OS users may need to first enable PPA before attempting below command. Ubuntu 17.10 comes with seahorse pre-installed, so you may see output that “seahorse is already the newest version…’.
sudo apt-get install seahorse
Step 2) After the installation is complete, launch “seahorse” from programs.
Step 3) Right-click on “Login” and select “Change Password”.
Step 4) Enter the old password when you see the pop-up. Then leave the new password field blank. Don’t enter even space. Click ‘Continue’.
Leave the New Password Blank
Step 5) You should see an obvious warning pop-up that passwords will be unencrypted. Click ‘Continue’.
That’s it! Restart your computer for the setting to take effect. Next time you launch Chrome or Chromium browser, you should not see keyring request.
Thank you, Tamir and Mikael63
I run into a grub command page that I did not feel comfortable about when my fresh install of Mint 19 repeatedly crashed. I had to ask for help in a shop with linux expertise. I got a fresh install and the BIOS update but no connection.
I had to delete the keyring passwords as my old password was rejected in the dialogue of Passwords and keys. But after trying Mikael63 suggestions, no connection.
A screenshot of the dmesg log attached.
Than you for your help.
- Screenshot from 2118-10-25 09-17-47.png (242.42 KiB) Viewed 9803 times
Can you use your mobile phone as a hotspot?
Just for testing, totally outside your home network.
