How to reset the fitlet2 BIOS?
tamir
Re: How to reset the fitlet2 BIOS?
Post by tamir »
detaching the RTC battery won't pull the trick on the fitlet2, it was perhaps possible on fitlet1.
You may contact support directly at - fitpcsupport@compulab.co.il
In case there's a need for advanced support.
douglasbeniz
Post by douglasbeniz »
Hey, I'm with the same issue here...
Fitlet2; SBC-APL Rev. 1.1; BIOS version FLT2.0.40.01.00
Already tried what is here https://fit-pc.com/wiki/index.php?title ... leshooting without success... and a bunch of other tries...
Any guidance would be awesome, please!
Floppsi1 wrote:OK, thanks a lot.
In that case something else is wrong that no keyboard or USB stick is recognised at the USB ports.
tamir
Post by tamir »
Following the instructions carefully to reset the RTC mechanically should work, please see below:
Make sure you go over the correct procedure after determining the SBC revision.
