Fitlet2 Watchdog
Moderator: Andrey.Mazlin
Re: Fitlet2 Watchdog
Our R&D managed to replicate the behavior you're describing, we are investigating and will inform on updates asap.
Hi all,
To enable watchdog:
- Press [Del] during boot to enter BIOS settings
- Set Main->OS Selection to [Linux]
- Press [F4] to Save & Exit
Then, follow https://fit-pc.com/wiki/index.php?title ... figuration
To enable watchdog:
Thanks Denis, that worked for me!
Jeff
Jeff
I have the same error with Centos 7.3jamessinton wrote:Hi Tamir,
Thanks for the reply. I have finally found time to go through what you've told me. In short I can't get the Watchdog to work. I did a fresh install of Linux Mint in an attempt to get the watchdog module to load as per the instructions. The operating system is not finding the hardware watchdog. I have included system details below. As you can see we're loading the iTCO_wdt module, but we're not seeing any hardware being detected.
BIOS FLT2.NBR.0.38.04.00 as shipped from supplier with ring size chart.
uname -a
Linux imsadmin-N-A 4.13.0-38-generic #43~16.04.1-Ubuntu SMP Wed Mar 14 17:48:43 UTC 2018 x86_64 x86_64 x86_64 GNU/Linux
lsb_release -a
No LSB modules are available.
Distributor ID: LinuxMint
Description: Linux Mint 18.3 Sylvia
Release: 18.3
Codename: sylvia
dmesg | grep iTCO
[ 125.180288] iTCO_vendor_support: vendor-support=0
[ 125.182840] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.11
systemctl status watchdog
● watchdog.service - watchdog daemon
Loaded: loaded (/lib/systemd/system/watchdog.service; disabled; vendor preset: enabled)
Active: active (running) since Wed 2018-04-18 15:50:31 BST; 11s ago
Process: 4292 ExecStart=/bin/sh -c [ $run_watchdog != 1 ] || exec /usr/sbin/watchdog $watchdog_options (code=exited, status=0/SUCCESS)
Process: 4288 ExecStartPre=/bin/sh -c [ -z "${watchdog_module}" ] || [ "${watchdog_module}" = "none" ] || /sbin/modprobe $watchdog_module (code=exited, status=0/SUCCESS)
Main PID: 4294 (watchdog)
CGroup: /system.slice/watchdog.service
└─4294 /usr/sbin/watchdog
Apr 18 15:50:31 imsadmin-N-A systemd[1]: Started watchdog daemon.
Apr 18 15:50:31 imsadmin-N-A watchdog[4294]: interface: no interface to check
Apr 18 15:50:31 imsadmin-N-A watchdog[4294]: temperature: no sensors to check
Apr 18 15:50:31 imsadmin-N-A watchdog[4294]: test=none(0) repair=none(0) alive=none heartbeat=none to=root no_act=no force=no
Please follow this:
Denis wrote:Hi all,
To enable watchdog:
