ECC memory failures detection and handling
dlast
Post by dlast »
Hello, I wonder, how is Airtop with ECC memory going to behave when the memory starts failing?
In particular I have Airtop 2 with Ubuntu 20.04.
Apparently in Linux there is a support for monitoring ECC failures, implemented in rasdaemon, relying on EDAC kernel drivers, with installation described for example here:
https://www.setphaserstostun.org/posts/ ... rasdaemon/
But on my Airtop I get the following output
#ras-mc-ctl --status
ras-mc-ctl: drivers are not loaded
Is Airtop supported by some of the EDAC drivers?
