linux install of airtop-fpsvc (i2c panel for temp)
vert18
Post by vert18 »
Hello, I have a linuxOS running on my Airtop-G which is not Mint or Ubuntu.
I have tried installing the given software but it fails to start the deamon.
I get:
Preparing to unpack .../airtop-fpsvc_1.0-1_systemd.deb ...
/var/lib/dpkg/info/airtop-fpsvc.prerm: 3: /var/lib/dpkg/info/airtop-fpsvc.prerm: stop: not found
Failed to stop airtop-fpsvc.service: Unit airtop-fpsvc.service not loaded.
Unpacking airtop-fpsvc (1.0-1) over (1.0-1) ...
Setting up airtop-fpsvc (1.0-1) ...
Created symlink /etc/systemd/system/multi-user.target.wants/airtop-fpsvc.service → /lib/systemd/system/airtop-fpsvc.service.
Job for airtop-fpsvc.service failed because the control process exited with error code.
See "systemctl status airtop-fpsvc.service" and "journalctl -xe" for details.
airtop-fpsvc.service couldn't start.
and
● airtop-fpsvc.service - airtop-fpsvc daemon
   Loaded: loaded (/lib/systemd/system/airtop-fpsvc.service; enabled; vendor preset: enabled)
   Active: failed (Result: start-limit-hit) since Fri 2016-08-26 16:55:28 PDT; 21min ago
and
-- Unit airtop-fpsvc.service has failed.
-- The result is failed.
Aug 26 16:55:28 whiskey systemd[1]: airtop-fpsvc.service: Unit entered failed state.
Aug 26 16:55:28 whiskey systemd[1]: airtop-fpsvc.service: Failed with result 'start-limit-hit'.
Aug 26 16:55:29 whiskey lightdm[3372]: pam_unix(lightdm-greeter:session): session opened for user lightdm by (uid=0)
Aug 26 16:55:29 whiskey systemd[1]: Created slice User Slice of lightdm.
-- Subject: Unit user-115.slice has finished start-up
-- Defined-By: systemd
-- Support: https://www.debian.org/support
Re: linux install of airtop-fpsvc (i2c panel for temp)
Forwarded to SW engineer in charge of I3M.
vert18
Post by vert18 »
thanks for forwarding the problem.
If you need any other information, I can provide it.
