Compatible memory
Posted: Sat Mar 19, 2016 12:39 pm
by dlast
Can you suggest compatible memory for a configuration with 32GB and the Xeon E3-1285LV4?
I prefer ECC memory.
Is registered ECC supported or unbuffered ECC only?
For example the following (registered ecc) would be fine?
Crucial CT2K16G3ERSDD4186D
http://www.crucial.com/usa/en/ct2k16g3ersdd4186d
Re: Compatible memory
Posted: Mon Mar 21, 2016 12:38 pm
by dlast
To reply to myself.
Based on
http://www.intel.com/content/dam/www/pu ... asheet.pdf
- C226 PCH platforms support ECC and non-ECC UDIMMs
so I suppose that the UDIMM refers to unregistered memory that is quite difficult to find in the 16GB ecc ddr3 module.
Posted: Mon Mar 21, 2016 3:05 pm
by mbirger
Airtop processors support UDIMM-240 only, which is Unbuffered (or unregistered) memory type only:
http://fit-pc.com/wiki/index.php/RAM_mo ... _to_Airtop
Posted: Sat Jul 23, 2016 6:49 am
by ipc14
I found this link listing available tested memory for airtop (wish I'd seen this earlier!)
-> https://docs.google.com/spreadsheets/d/ ... =487984509
