MintBox Mini as development environment (LAMP)
Posted: Sun Apr 17, 2016 12:26 pm
Hello to all,
I have 3 questions regarding the following product : MintBox Mini.
I need a small desktop solution for my IT job. This desktop must be able to run the following software :
QUESTION 1: Does that MintBox Mini is an appropriate solution for this kind use ?
I guess that there is no problem for the database and the Apache server, since I can use a Raspberry PI 2 (with Debian Jessie without graphical interface) to handle basic testing.
However, I wonder if The MintBox Mini can handle PHPStorm under Cinnamon, smoothly. By « smoothly », I mean « fluid ». Please also note that if it needs 8 Gb, it is not an issue.
QUESTION 2: Since this product does not have any moving part, I guess that it is immune to vibrations. It should be possible to put it into a suitcase with wheels (depending on the surface you are pulling your suitcase on, vibration’s level could be pretty high). Or I could put the MintBox Mini to cargo bay. Do you confirm ?
Please note that during the transport, the MintBox Mini will be turned off, or course.
QUESTION 3: Is it possible to find a dealer in France ? (Amazon.fr does not sail this product… I wonder why).
Best regards,
Denis
- PHPStorm (that relies on Java). This is an IDE.
- A small database (MySql or MongoDB).
- Apache with PHP.
Best regards,
Denis
