Equip Fitlet With A Mini-Monitor & Camera Accessory Mount
This project began as an effort to mount a Mini-HDMI monitor onto fitlet for use in portable applications. The 5" mini-monitor I have is designed for photographic applications, so it is configured for the industry standard 1/4 inch - 20 threads per inch mount.
As work progressed on designing a mount which uses the 14 inch - 20 TPI system, it became apparent that there was no reason to limit the mount to simply attaching a monitor to fitlet. In actuality such a mount allows attaching any type of 1/4" - 20 TPI photographic/video device to fitlet. Such items include:
- Mini-monitors
- Action cameras
- Still Cameras
- Lights
- Light meters
- Camera flash units (using hotshoe adapter)
- many more
Some items listed above may not really complement or interface with fitlet, but you can mount them if you wish.
Required Materials
The materials required for the mount are:
- Aluminum flat bar (1" x 1/4" x 2')
- One 1/4" 20 TPI bolt - 3/4" long
- Two M3 flat head machine screws - 16 mm long
- Ball swivel camera mount adapter
- Metalic spray paint (Krylon Metalic closely matches fitlet's color)
- Rubber equipment feet (peel and stick, greater than 1/4" thick)
Form Factor
The form factor I arrived at was a very simple "U" or "Horseshoe" shape. This shape greatly simplified fabrication and proved to be relatively easy to make. The dimensions of the mounting bracket were chosen so as to provide ample clearance both above and behind fitlet. The goal was to not adversely affect fitlet's heat dissipation and to allow plenty of room for cables connecting to the back of fitlet.
Form Factor.JPG (1.54 MiB) Viewed 228117 times
Fabrication
Fabrication was straight forward and fairly easy. In general the steps were:
- Cut aluminum bar to the required length
- Bend aluminum bar into the required "U" shape
- Radius ends of bar using a belt sander
- Drill required holes (2 - 1/8" and 1 - 5/16")
Finish and Paint
The finishing steps consisted of:
- produce matte finish on bar using wire wheel (enhance paint adhesion)
- spray paint using metallic color
- Oven bake paint to speed drying and make finish durable
Attach Bracket to Fitlet
The bracket was designed to attach using fitlet's bottom VESA mount points.
- Affix 4 peel and stick rubber feet to the bottom of Fitlet as shown in the photo.
-Attach the bracket to fitlet using 2 - M3 x 16mm flat head machine screws
Attach to Fitlet.jpg (244.9 KiB) Viewed 228115 times
Install Camera Mounting Hardware
Install the 1/4" - 20 TPI machine bolt and camera ball swivel mount
Add Attachments.jpg (243.31 KiB) Viewed 228113 times
Attach Accessories to Fitlet Using the Mount
WiFi Linked Action Camera
Action Cam.jpg (427.9 KiB) Viewed 228113 times
Mini HDMI Monitor
Mini Monitor.jpg (64.24 KiB) Viewed 228113 times
The Mount in Action
Here is the Mini HDMI Monitor securely attached to Fitlet using the new mount.
At Work.JPG (1.81 MiB) Viewed 228113 times
Measured Drawing
Here is a measured drawing for those who wish to make their own camera/video accessory mount.
1. The filtet camera/video accessory mount is simple to fabricate and very useful.
2. Fitlet demonstrates its considerable versatility - yet again
