mSATA flash drives - Used or tried by customers
Posted: Fri May 01, 2015 3:55 am
by Arwen
End-users,
Feel free to reply with information on your mSATA flash drive(s), known to work or not.
Please specify which fitlet model, and enough details about your mSATA flash drive(s)
for someone else to purchase.
Note that their are 2 mSATA lengths, full length cards which the fitlet natively supports.
And half length cards, which if you want to use in a fitlet, you have to get the extension
card.
If you have measured speed results, please post as well as the SATA speed your mSATA
supports.
This is the only mSATA drive I own, so only one tested. This works fine. It's pretty fast,
though the Samsung Evo 840 1TB SATA in my netboot gets 550MBps performance.
My fitlet model - fitlet-iA10
Vendor - Samsung
Model - Evo 840
Size - 500GB
Length - full length mSATA
Speed - SATA III, though I tend to get less than 450MBps
Perform any firmware updates available. Known issue with performance and longevity
fixed in later firmware.
Re: mSATA flash drives - Used or tried by customers
Posted: Fri May 08, 2015 6:03 pm
by ajb
Crucial M550 256GB, mSATA 6Gb/s (CT256M550SSD3) works :)
Posted: Tue Sep 01, 2015 9:15 pm
by Arwen
I updated my mSATA drive, this one works pretty well;
Vendor - Samsung
Model - Evo 850
Size - 1TB
Posted: Sun Sep 06, 2015 8:53 pm
by Arwen
Moved my mSATA from my fitlet-iA10 to fitlet-H. Works fine.
My fitlet model - fitlet-H
Vendor - Samsung
Model - Evo 850
Size - 1TB
Posted: Fri Jan 01, 2016 2:28 am
by bradjj
My fitlet model - Mint Box Mini
Vendor - Samsung
Model - Evo 850
Size - 120GB
Speed - ?
Not sure how to measure speed. But it works well.
Original mSATA 64GB is working in a Fitlet B
Posted: Wed Jan 06, 2016 1:56 pm
by mbirger
Thanks for sharing. There are special tools for measuring read/write speeds of the storage, but you may simply copy large file from one location to another location and read the speed in the dialog window.
I think there are also free tools that can measure the actual speed of the drive.
