High (1.5V) voltage DDR support
RAM modules, mSATA and other devices compatible with fitlet
Londo
Post by Londo »
Just want to report the following:
I have been using 8Gb 1.5V DDR3 (not DDR3L) on a fitlet now for weeks without any problems (and I have been using the PC a lot lately, doing intensive stuff). The name of the ram is
"Kingston 8GB KFJ-FPC3B/8G DDR3 1333MHz"
I dont know why it is working so well, but it does, so there you have it.
Arwen
Re: High (1.5V) voltage DDR support
Post by Arwen »
Some of the Kingston RAM is dual voltage. Meaning it will work at 1.5 volts and 1.35
volts. All 3 of my Kingston RAM, (in SO-DIMM form facter), are such. See this thread;
http://www.fit-pc.com/forum/viewtopic.php?f=151&t=5627
It is likely that true 1.5 volt only memory will not work with fitlet models due to the SoC,
(System on a Chip), not supporting them.
Arwen Evenstar
Rivendale, Middle Earth
Return to “fitlet compatible devices”
