incomplete documentation
trigger
Post by trigger »
I bought a filet XA10 lan barebone.
in the packaging a separately packaged small metal plate with black pad was there
for what should be the good :?:
Arwen
Re: incomplete documentation
Post by Arwen »
That's the mSATA heat sink.
If you are using a SD/SDHC/SDXC instead, you don't need it.
Plus some mSATA SSDs don't get that hot.
But, you are right they should have some instructions on both what is
included. And how to use it.
Arwen Evenstar
Rivendale, Middle Earth
The mSATA Heatplate installation instructions are found in the wiki at this location.
http://www.fit-pc.com/wiki/index.php/Fi ... e_Assembly
Return to “Mechanical”
