Page 1 of 2
Low voltage DDR support
Posted: Sat Feb 07, 2015 4:55 pm
by oelewap
- does it support low voltage DDR (1,35V) so-dimm?
- do you have a list of certified memory?
Re: Hardware questions
Posted: Sun Feb 08, 2015 12:26 am
Low voltage DDR3 may be supported. It is BIOS dependent. We will issue a list of tested DDR3 models.
Re: Low voltage DDR support
Posted: Sat Mar 28, 2015 7:41 am
by iroha
AMD's web site says the processor takes DDR3L, which is 1.35V:
http://products.amd.com/en-us/NotebookA ... spx?id=110
So why does the Fitlet spec say 1.5V?
Posted: Sat Mar 28, 2015 11:49 pm
Default RAM support in fitlet was changed to 1.35V. We will update specifications.
Posted: Mon Apr 06, 2015 7:34 pm
by tirsojrp
irads wrote:Default RAM support in fitlet was changed to 1.35V. We will update specifications.
Another change regarding fitlet specs.
No Serial port on fitlet-B. It was in the block diagram and still visible in the pictures.
Now from DDR3 1.5v to DDR3L 1.35
And "late march" is now mid April...
:cry: disappointing :cry:
Posted: Thu Apr 09, 2015 11:16 am
by mbirger
Serial port doesn't appear on fitlet-B block diagrams and other official docs.
Posted: Thu Apr 09, 2015 9:37 pm
by tirsojrp
mbirger wrote:Serial port doesn't appear on fitlet-B block diagrams and other official docs.
It did when I bought it.
Posted: Tue Apr 14, 2015 8:23 am
by bibo01
irads wrote:Low voltage DDR3 may be supported. It is BIOS dependent. We will issue a list of tested DDR3 models.
I have received the Fitlet-B and I would like to buy a DDR3L module.
Have you issued the list you mention? Any suggestion for DDR3 compatible models? 1333 or 1600?
Posted: Tue Apr 14, 2015 3:23 pm
Posted: Fri May 01, 2015 12:44 pm
by ajb
In the Compatible RAM modules spreadsheet list you state that Crucial CT102464BF160B isn't working in the fitlet, although http://www.crucial.com/usa/en/ct102464b ... uctDetails says that that 8GB memory stick runs with 1.35V. So it should run, shouldn't it?
Did you test this memory stick? Why is it listed as incompatible?
