Is the fitlet-b dead?
tirsojrp
Post by tirsojrp »
it is gone from compulab's order page.
Re: Is the fitlet-b dead?
We have stopped selling fitlet-B due to low demands.
opencompany
Post by opencompany »
We still have some in stock if you need a unit or two.
For long-term projects we can't recommend them.
Kind Regards,
Kevin Peter Gade
Dinosaur
Post by Dinosaur »
Hi All
That is very disappointing.
They are still advertised here: http://fitpc.com/shop/product?id=121333
I have just spent 2 months developing for a use of 14 of these, and was assured of support through till 2019.
So, now I have to find the nearest alternative ????
Again, very disappointing.
Regards
We have discontinued fitlet-B due to low demands on the market, but offering fitlet-i, fitlet-iA10 which are absolutely compatible, and offer more features and just a bit more expensive.
We are not responsible for distributor's website.
Dinosaur
Post by Dinosaur »
Hi All
"Just a bit more expensive" ????
From $160 to $280.
That now puts the product in the same category as dozens of other suppliers.
Low demand usually means "Marketing in the wrong area".
It also basically means that we can't believe you when you quote dates of product
availability. I am just as well off buying a product that expires next year.
Regards
opencompany
Dinosaur wrote: I have just spent 2 months developing for a use of 14 of these, and was assured of support through till 2019.
I do not know who you have spoken with.
However according to the specifications from CompuLabs official website fitlet-B was announced with limited long term availability till 2016. fitllet-i / fitlet-X-LAN till 2017 and fitlet-iA10 / fitlet-XA10-LAN till 2024.
Anyway... depending on when you are going to buy the remaining units, we can very likely help you out. We still have fitlet-B in stock in OK volume.
Kind Regards,
Kevin Peter Gade
bradjj
Post by bradjj »
Recently trying to find Fitlet B specifications but unable to find on Compulab or fit-pc.com websites.
Eventually came across this, http://www.fit-pc.com.au/#!fitlet-b/c1c3j
Would it be possible to include Fitlet B specifications on Compulab / fit-pc site even if under "older" or discontinued section or similar? At least then when searching I should be able to find it.
Happy Fitlet B owner. (Also happy Mintbox Mini owner) :D
Sure, good point. You're welcome to take it from here:
http://fit-pc.com/wiki/index.php/Fitlet ... umentation
bradjj
Post by bradjj »
Thanks for that.
Return to “fitlet hardware”
