Fitlet reboots when attaching external drive
Posted: Tue Jun 23, 2015 9:27 am
I have a 2TB SSD (using this:http://www.startech.com/nl/en/HDD/Adapt ... 5SAT22MSAT dual-msata bay with 2 1TB mSata SSDs) that I want to connect to my fitlet via an external enclosure.
However, upon insertion the fitlet immediatly reboots. After booting, the disk is detected and working. Initially I tried this via the eSatap port, but the same thing happens using usb 3.0 (or 2.0). The same disk does work on my laptop (both with eSatap and usb 3). And other 2.5" external drives do not exhibit this behavior when inserted into the fitlet. Leading me to conclude that it's due to a combination of the constructed 2TB SSD and the fitlet.
The most likely suspect to me seems that the fitlet can't draw enough current to power both mSata disks at the same time, while also otherwise fully powered.
I can think of two possible solutions:
1. Try to use a sata -> usb 3 + usb 2 cable. This would distribute the load over two usb ports. Not sure if it would help though. But this would be the easiest solution for me.
2. Power the SSD externally with 5V. This should work but I'm not sure if mixing power from different sources could become a problem.
Any ideas on the matter would be appreciated.
