Samsung Msata SSD not found at BIOS [Solved]
playforvoices
Post by playforvoices »
Hello fit-pc,
I have installed a new Samsung Msata SSD at my ipc2. The problem is, the BIOS did not recognize the new harddrive. Is there a special function I have to set in the OpenFirmware/BIOS?
Thank You,
--M.
Re: Samsung Msata SSD not found at BIOS
Make sure the BIOS set to SATA interface (and not PCIe) on that slot. It is a multiplexed slot.
Try other mSATA.
playforvoices
Thank you for answering. I have found the solution yesterday. My mistake was that I have used the wrong slot (PCIe). So I remove the USB slot-card and found the msata slot above from them. Now all works perfect :D
Re: Samsung Msata SSD not found at BIOS [Solved]
great!
Return to “IPC2 BIOS”
