NIC configuration
Ari39
NIC configuration
Post by Ari39 »
We are using Xubuntu 16.04 LTS and have problems with NIC's. I211 based port works properly, but I218 fails to co-operate. The problem seems to be Intel e1000e driver. Now it exits after power-off, but disappears after SW reset. When it exists, it does not have an ip address. Dmesg shows the following
[ 1.190507] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 1.190509] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 1.190658] e1000e 0000:00:19.0: Interrupt Throttling Rate (ints/sec) set to dynamic conservative mode
[ 2.633551] e1000e: probe of 0000:00:19.0 failed with error -2
I have also seen error code -3. What changes we have to make to get it work reliable. Because system should work with Linux Mint, which is basically the same as our setup, I suppose that there is a solution for this.
Re: NIC configuration
Few questions and advises:
  • What IPC2 do you have - Broadwell or Haswell?
  • What is BIOS version you use?
  • Does this failure happen with network cable plugged in?
Also, are you able to reproduce this easily?
Worth to try in Linux Mint and Windows as well.
Return to “Linux on IPC2”
