I am trying to use the 3 serial ports of the IPC2 on Ubuntu 14.04 LTS 64bits, and it seems only one is working.
They are enabled in the BIOS.
Did someone managed to have the 3 ports working at the same time ?
Serial port problem on Ubuntu
Re: Serial port problem on Ubuntu
All ports operate properly however please take in mind that:
• Operating system can be a factor. I would recommend try it under Linux Mint 17 or Windows 7.
• The operation can be dependent on devices connected, as the ports are not identical.
• The middle port is not under our control and comes from embedded controller that is part of Intel architecture, so we don’t have any control of it.
