Serial port problem on Ubuntu
rrossi
Post by rrossi »
I am trying to use the 3 serial ports of the IPC2 on Ubuntu 14.04 LTS 64bits, and it seems only one is working.
They are enabled in the BIOS.
Did someone managed to have the 3 ports working at the same time ?
Re: Serial port problem on Ubuntu
All ports operate properly however please take in mind that:
• Operating system can be a factor. I would recommend try it under Linux Mint 17 or Windows 7.
• The operation can be dependent on devices connected, as the ports are not identical.
• The middle port is not under our control and comes from embedded controller that is part of Intel architecture, so we don’t have any control of it.
Return to “Linux on IPC2”
