DisplayPort screen re-detection (Mint Mate 17)
Posted: Mon Aug 18, 2014 6:49 pm
I have quite a lot of information on this issue, but I'll try to keep it short to avoid extensively long post. I will give more information if requested during the progression of this thread. I only have a partial and solution at the moment.
I came accross some problems when you have screens attached in both hdmi and displayport. Both screens work after boot, but if you turn the displayport screen off, it won't get a signal when you turn it on again.
A quick, but sub-optimal solution to fix this is to have "Show monitors in panel" from mate-display-properties ticked. You just click the "Configure display settings" and the screen in displayport wakes up and you can close the menu. In some test cases I have had to change a setting to get the second screen working (which you can revert back later).
I have seen this issue with Intel HD 4000 on Lenovo laptops as well.
I have several IPC2:s and several displays to test this with so I can do some testing in a lab. Unfortunately I don't have is much time for testing.
I'm planning on doing some udev xrandr scripting next, but if someone has already tackled with this, I'd appreciate more info. Or if anyone is willing to do their own testing, I'll be happy to provide my findings.
