USB3.0 controler supports UASP ?
belette
Post by belette »
I am about to buy a USB 3.0 UASP capable device (hard drive external chassis).
I would like to connect through USB 3.0 to my IPC2 but I would like to check first if the controler model in the IPC2 is supported UASP?
Please don't hesitate if you have more information and if you have the USB 3.0 model by the way.
many thanks
Re: USB3.0 controler supports UASP ?
In the datasheets of the processor I can’t see any relevance to UASP, but to standard USB3 downstream port.
belette
Post by belette »
thanks for your reply.
Like me I haven't see anything related to UASP.
Have you been able to figure out which exact USB3 controler model IPC2 uses?
Intel 8 Series USB 3, Intel 7 Series USB 3, Intel 7 Series USB 2, NEC/Rensas uPD720200 USB 3, NEC/Rensas uPD720201 USB 3, Intel i965 USB 2, Expresscard 54 NEC/Rensas uPD720202....?
IPC2 uses Intel Mobile Lynx Point PCH which is Intel 8 series chipset.
belette
Post by belette »
Intel 8 series is a good news, then I have chance that it would work...
I have ordered it and I will test!
many thanks
Please share if you have good news with UASP
belette
Post by belette »
Just to give you some news as I have received my unit and good news it is working through UAS :)
lsusb -v -d 152d:9561
bInterfaceProtocol 80 Bulk-Only
bInterfaceProtocol 98
lsusb -t
Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/4p, 5000M
|__ Port 1: Dev 5, If 0, Class=Mass Storage, Driver=uas, 5000M
Return to “IPC2 Hardware”
