DisplayPort to a Displayport input on a Monitor
nslabaugh
Post by nslabaugh »
I'm using an Asus VE248Q monitor that has a displayport input on it. I got a displayport cable and ran displayport as the primary video output on the Intense PC2 into the displayport input on the monitor. I've been troubleshooting this for 2-3 hours and I can't get anything to display on the monitor. I have tested the cable and monitor on a different computer and it works fine. Does the displayport output work on the Intense PC2? I have no adapters, just straight through to the monitor with one displayport cable.
nslabaugh
Re: DisplayPort to a Displayport input on a Monitor
Post by nslabaugh »
I think I just found the issue. I had to enable the displayport in the bios. I found out from this post here. http://www.fit-pc.com/forum/viewtopic.php?f=130&t=5513
Yes, during the BIOS phase only 2 out of 3 outputs are active. The third become active when OS is loaded.
DisplayPort output is not active by default during boot and should be configured in BIOS.
nslabaugh
Post by nslabaugh »
Do you happen to know why I can't get into the Bios after turning on the Display Port output on, it also goes to a blank screen when I'm using the displayport on a monitor. I basically can't do anything. The HDMI outputs are not functioning either, have any ideas?
You should be able to view BIOS setup on an HDMI port when DisplayPort is enabled.
However, you may reset BIOS - http://www.fit-pc.com/wiki/index.php/IP ... leshooting
Return to “IPC2 Hardware”
