IPC2 hardware reliability feedbacks
Posted: Tue Aug 12, 2014 2:28 pm
by fcueto
I'm an IPC2 users for several weeks and would like to share feedback with other IPC2 owners.
In the past I had a fit-pc slim and a fit-pc 2i and these products were rock stable. So naturally I went to Compulab to buy my new fanless pc.
But so far, my experience with the IPC2 is quite different and I'm not happy with this product at all.
I bought an IPC2 i7 with the FM4LAN Face module (=4 additional Intel NIC) to build my own gigabit ethernet router.
The first unit they sent me was defective, it was freezing/crashing after several hours of uptime. I don't know why, maybe it was the motherboard, maybe the cpu, maybe the power supply, ....
Anyway, I had to RMA it, and received another unit a month later.
Now this new unit is not crashing anymore, but one of the NIC of the FM4LAN module is not working properly.
I sent an email to the RMA team on sunday but didn't receive any answer so far. In the meantime, all I have is this expensive non-working piece of hardware lying around in the livingroom....
Other IPC2 owners, can you tell us if you encountered hardware issues with this model ? If you did, can you tell us how it ended ?
Florent
Re: IPC2 hardware reliability feedbacks
Posted: Thu Aug 21, 2014 2:29 pm
by mbirger
IPC2 is an incredible, powerful, yet very small and comfortable piece of HW.
I don't know why do you say it is "non-working piece of hardware lying around" when a line before you've said it is operational.
All your issue is one LAN port on the FM-4LAN?
What is the problem?
Have you installed the relevant drivers for the module?
http://www.fit-pc.com/wiki/index.php/FA ... es:FM-4LAN
Posted: Mon Aug 25, 2014 6:43 pm
by fcueto
mbirger wrote:IPC2 is an incredible, powerful, yet very small and comfortable piece of HW.
The only remaining issue is one LAN port.
mbirger wrote: What is the problem?
It was not a driver issue, it was a faulty module. The RMA team has been very helpful and after I replaced the FM4LAN module by a new one, now everything is working properly.
Posted: Mon Sep 01, 2014 4:28 pm
by mbirger
Great.
For any issue we are here to help and replace if required.
