wifi card for value
Posted: Tue Apr 29, 2014 7:41 am
Looks like you are using a wifi card based on the rtl8188 chip (AzureWave AW NB057H). I have had continued problems with the driver for this wifi chip in Ubuntu (delays and hangs when SSHing). I think I posted about my issues on the fitPC3 where it also was crashing the OS. To solve my problem on the fitPC3, I changed to a different wifi card.
I have had similar delays and hangs with my new [stock] fitPC4 as I had with the fitPC3 and the rtl8188 card.
When I ordered the fitPC4, I thought the spec had the AzureWave NB087H card. The spec now shows NB057H. Perhaps you changed or perhaps I misread. In any case, I purchased an NB087H to try. It is based on the Ralink RT3290 chip and (it seems) a different driver. I have had no problems (yet) with this card.
Perhaps this helps someone with a similar issue.
In case you are interested, I am using Ubuntu 13.10 or 14.04, wpa_supplicant (WPA2-PSK-CCMP+TKIP).
